So, I'm an old fart with about 20 years rc experience with fixed wing and limited rotary wing.  I get an ARParrot quad and think "this looks like it could be fun!".  I order a Century Neo 600 with NAZA M Lite with GPS and it goes together fine.  I set parameters using Assistant Lite: I set GPS mode, course home lock, GPS/IOC on; I power up and the quad tilted right and cut my leg requiring 10 stitches (really far apart :upset: !  I replace all 4 props (this time I sanded the moulding flash off the edges) and power up again while standing 15 feet away.  This time, with Attitude mode set,  it went up about 4 feet, started tilting forward, increased motor speed, and went for my neck before it hit the house.  I checked motor speed with 3-way switch at Manual, props on at idle, center, and max and got readings +/- 200 rpm on all 4 motors.  So it's not a problem with props, motors, ESCs, or throttle control.  (By the way, this set up is waaaay too powerful - just one motor will lift the 1500gram quad!!).
Is there anyway to look at the NAZA's autopilot response curves to barometer and gyro inputs? Is there anyway to look at NAZA's barometer and gyro outputs?
