htotheunit
Hello,
After my incident last week, I fixed my hexa replacing all but one of the arms, two motors and the rest of the broken bits.
However I now have some major issues with my compass. I remounted it where it used to be on the top plate which resulted in green/yellow flashing. After successfully calibrate it several times I moved it up onto another standoff plate well above the rest of the electronics. This appeared to work for a lengthy hover test and around 10 flights afterwards. Then I began getting the green and yellow lights flashing again, with the hex flying in atti mode periodically regaining compass data before losing it again.
A couple of weeks earlier I did notice some odd behaviour before the crash flight, The copter appeared to fly forward before quickly levelling off even though my stick was forward before continuing on its path. On these occasions the light was again yellow and green, is this normal should the compass data be lost during movement?
Is there any way in which I can test the compass for faults?
Here's a picture of my setup, apologies it's sideways I would fix it but I have to go somewhere in a minute!
