I am having a strange problem. I put together a DJI 450 frame with a Naza-Lite, T-Motors 2212-16 750KV with 10 x 4.7 APC props. I am using a 4400mah 3S 65C battery. I don't get full power right away. If I hold it in my hand above my head the same thing. You can hear the motors picking up speed for about 15 seconds after starting and putting the throttle at full power. I am using one of those Hobby King ESC's with 4 in 1 rated at 20 amps per channel. I'm starting to wonder if that wasn't such a good idea and maybe I'll go back to 4 separate ESC's. I did the ESC throttle Calibration and also the Calibration in the Naza - Lite. Maybe the ESC is getting too hot out here in the desert - Palm Springs before it even starts. I've have used these motors before and they have worked fine. I have never used a Naza-Lite. Just WKM and Naza V1 and V2. This is also the first time using the 4 in one ESC. I am running a Futaba Transmitter with an FRSky Futaba compatible receiver in S bus mode.
I just noticed that in Manual mode I have full power right away. When in GPS mode is when I don't get full power right away.
Rich
Rich
