Is there really an advantage of 3S vs 4s for an f550
gencode
Is there really an advantage of getting a 2200 4S over a 3S, I assume since both are 2200 they both would give the same flight time but the 3S is lighter so seems as it should be even better flight time and give you more payload weight for other things.
the 4s if setup right will make more watts with less amps. watts is amps times volts. it all depends if you need the power or not. it involves re propping to make work right, usually a size or two smaller like 8" or 9" depending on the load it carries
gencode
I have a f550 with Gimbal and GoPro and FPV so its pretty loaded up.
Guess it seems that if I went back to the 3S would it get me more air time since it will be carrying less weight?
and it changes frequencies so it goes both ways. sometimes that makes your jello better, sometimes not depending on the hardness of the mount and how it matches the frequency. the heavier blade will make them a deeper wave...... ie. longer = heavier
thats a professional cure so none of it matters
https://vibrationmounts.com/eStore/...th=http://vibrationmounts.com/RFQ/VM08009.htm
and ear plugs are about the same hardness, matches a multirotor perfect. Ones a hundred, the other is $2
no question 4s is better all around. More power, more efficient, higher prop speed will show much less rolling shutter if none at all, better in wind.....
2tall
Fly Often - Fly Safe
faster spinning props gives more vibrations
I'm not sure how accurate that is. My RC helis really show the effect of blade balance during spool-up, but as the head speed gets closer to flying RPM everything becomes very smooth. This holds true with full scale helis as well.
Jon
I agree, switched over to 4S months ago on my F450 and it was a huge improvement over the 3's, using 8" props with the 4S
-Don
