LeeT
Wannabe AP Dude
I finally finished dialing in my 650 hex. I am very pleased at how it responds and how locked in it is with the GPS on. I took it out to do some AP over a section of deserted wetlands (Florida). I am using a GoPro Black with 32gb class 10 SD card, 30 FPS 1080P. I have three issues:
Jello - I believe I found the culprit, the gimbal (H3-2D) could rock slightly side to side. I modified the mounting plate so that I bolted down the side mounts. It is rock solid now. I also changed out the dampers from the grey ones (medium) to the white ones (soft). The props are Graupner, and are balanced horizontally and the at the hub. Hopefully this should minimize the jello issue, have not yet had a chance to try it out yet.
Horizontal Scrolling - I am not sure I am using the correct term, there are faint horizontal lines that scroll top to bottom. I believe my camera should have been point more towards the ground, but not really sure what causes this.
Pieces of the video drop out. There are a few places in the video where small pieces of the video go black, or get static. It only happened a couple of times and for a very short time. It is easily edited out. I'd like to know what causes it (bad sd card maybe?) so that I can prevent it. I have purchased a new SD card as they are only $20 to replace the current one.
If it would help I can put together a short video with all conditions and post to YouTube.
Thanks,
Lee
Thanks,
Lee
