Here is a video of my pan acting up this evening. I never touched the transmitter while it was doing this, speed and direction changes it was doing on its own.
http://youtu.be/HSXIZrMHqCw?hd=1
Here is a video showing some of my footage with the gimbal with pan disabled, and a velcro strap from one boom of the multi to the gimbal(to keep it from spinning because the servo has no holding power while in slew mode(not being controlled, just has power basically) Since this video I have taken my gimbal off of my multi(as seen above) to rebalance it and install my downlink etc. Very little post added to a few of the shots, the rest are raw.
http://youtu.be/6K04Lcg_caU?hd=1
haha, I may be selling my HF gimbal board and picking up the free fly radian. Just very frustrating dealing with the pan issue.
Ok ready for the deal??
The Pan compensation is working based on the magnetometer. You can expect good results with any magnetic sources, such as your computer, nearby.
Hi Al,
do you plan for the pan to be stabilised by Gyro too? It is incredibly slow to react and has over 30 degrees of drift with the mag alone.
Also, there seems to be no user control when in Pan stabilised mode. Is this correct or have I missed a step.
Matt
Hi,
I'm still having trouble with the new HFG on an AV200. Software version 1.03, Hardware 1.0
The Roll is very slow and the roll gains do not actually change the speed of the roll. The other roll settings work.
The tilt is working fine and works as expected with all the software functions.
The pan is just not working right and seems to be magnetometer only functionality which will never work for Pro AP.
Could someone help me:
1) get the roll working at expected levels
2) Let me know if gyro will ever be incorporated into Pan Stabilisation?
I'll cross post this with RCG.
Matt
Hi,
Matt
...........I'll cross post this with RCG..............
You will probably need to adjust the Set Ranges on the Receiver Configuration. You can set a maximum deflection rate.
Dan is about to release a new version of FW with enhanced Pan stabilization. I will let him comment on it.
That's great but is HFG considered a universal stablization solution? Not sure how well that will work if pan is stabilized by a magnetometer only. It seems to me that there are quite a few opportunities for a mag to be affected by outside influences...individual setups or influences from indoor flight. Idk..am I wrong?
