Had some time today with a multi rotor running the black hfp board and castle esc's. when i'd fire up the motors, there was a noticeable lag in 2 or 3 of em, one goes quite a ways into the throttle studdering till it spins. the esc is in multi rotor mode and fixed end points. When i tried to calibrate the throttle range, nothing would happen both straight to the receiver and through the hfp boards throttle range cali procedure.
How do it calibrate these things? i know in fixed endpoint mode per the castle esc whitepapers is the radio is set to the esc's range. how do you set that up in an hfp?
