Hey everyone
Chuggles
Hello to all. Yes I am brand new to RC flying. I just finished my 1st build. After buying a couple different RTF's that wouldn't fly and got returned. I figured I can build something that won't fly. So I built an XHover mini 230 with a cc3d from Lumenier, 1804 2400kv, 12 amp SimonK. On its maiden flight it hit pretty hard and stopped working. I am in the process of trying to figure out what is wrong. I am real good with mechanical stuff, not good at all with computers and electronics. I have replaced the rx, I replaced the tx as well. I am trying to use a Spektrum DX6, I was using a flysky th9x. I'm not sure where to start other than delete and erase to download all over again. Any one have any ideas? You don't have to hold my hand I will follow along obediently. I am glad to be here.
Thanks.
Motopreserve
Hey Chuggles. Welcome aboard!
Sorry to hear about your crash, but I'm sure you have seen that crashing is part of the experience - so seems like you have the right attitude. Back on the horse!
You mention swapping Tx/Rx. What was the reason? Were they not working?
When you say "stopped working," what exactly do you mean? Is there any power getting to any of the components? Do you hear sounds?
Give us some more details and we may be able to help you better.
Glad you found MRF. Plenty of help to be had here!
Chuggles
I am up flying again. The problem was the plug on the wires from rx would not snap into place.
I took the quad and tx to this dude I met to have him take a look. He text me after I dropped it off to him, said he has to erase and load everything. I said whatever get t working. I met this guy at an RC hobbie store where he works, he gave me some flyers to an event he was putting together for new or want to be pilots. I figured he has to know more than I do.
I met him to pick it up and he flew it, it was very unstable, he said if it had GPS it would be better. I asked him I told you that I have already flown this quad right? I said did you set up flight mode sw. he said yes, (he didn't) it flys the same in all of them he said. We were looking at it messing with the wires, he proceeded to tell me that open pilot hasn't released the cc3d with gps yet. Then he went to fly it again and nothing, I said that's what its been doing to me. Then I said its that wire. I took it home fixed the wire flew the quad and stuck it in the mud. It flew so much better the first time I flew it. I got it home and set up the F. mode switch after I blew all the mud out of the motor then flew it real low in my driveway. Flight mode 1 ( his) terrible, I would get rid of the quad if that's the best it could do, F mode 2 , very stable, hovered right in front of my face with little effort from me, I did configure an almost flat spot in the middle of the throttle curve. Don't remember if I tried F mode 3. It has something keeping it stable, if not GPS what. Now I need to set up return to launch. Thanks for being there ready to help Motopreserve, don't go away I am building another quad. The Turnigy Herculez 500 frame with a naza lite. It is almost done. I actually started on the 500, while waiting on a china parts delivery I went to the rc show in Ontario and came back with the XHover mini frame, then proceeded to order everything from USA suppliers so it got finished 1st.
Chuggles.
What all do I need to set up a return to launch feature and where would I find it? Anyone ?
Motopreserve
The function/mode that is keeping it level is not GPS, but what would be called ATTITUDE or horizon mode (or something similar - they all have some unique name for it).
Make sure you program in a manual mode for tuning. The open pilot community has good documentation for those boards. Make sure you keep a copy close at hand :)
Its good practice, after every crash (or whenever you fly really) to check all the wiring for loose connections.
Unfortunately you would need GPS for return to home/launch. That's what logs the location and allows the MR to return there.
