aerovantage
Hi need help on my S800 ..
I have set it up correctly and and flew 3 flights successfully. You can view it here :-
http://www.youtube.com/watch?v=wVuYWX0WQ14
Today on my 4th flight
1. It flew ok and i left it on GPS lock for about 5 mins while I work on zenmuse and the video downlink.
2. Then I apply right aileron and it started to to move to the right but at the same time it started to rotate left as well - which is weird
3. I then notice there is no light on the LED. (on ATT mode)
4. I immediately land the S800 and return home to check on Wookong assistant ..
I just checked all connection and it seems ok. I connect the battery to the S800 and Zenmuse (the Zenmuse initializes correctly) and connect the USB to my PC but it does not recognize the S800.
I restarted everything.. connect the battery then I realize the only initializing sound comes from the zenmuse and there is no other sound and there is still no light on the LED.
I checked again. connections all correct. But there is no power on the Radio Receiver (LED on the Futaba receiver did not lit up) and I suspect the there is no power on the Wookong too (PMU connected correctly to X1 on Wookong - yes I have had 4 sucessful flights)
But there is a green light on the PMU
Really appreciate any feedback..
