the 10x5 are strictly 8mm bore. what size are the motor shafts? can you use like this? http://www.v-eastonline.com/products/Air-screw-coupling-.html that's 4mm shaft, 8mm hub. they have some smaller shaft sized adaptors, but not many of then tighten enough to pinch a eprop. mailman showed me a link to electricwingman in the uk that had 3mm shaft 8mm hub adapters. might be others as well.
