As part of my recent MK FPV quad project I've been upgrading all my video gear and with the newfound freedom of video goggles with built in RX I decided to put together a grab and go FPV rig that requires minimal gear to get in the air. What I did was soft mount both an SN 777 camera with an Immersion 100 mw TX and cloverleaf antenna on my DJI F450 with Naza controller. The F450 along with the JR 11X and Fatshark dominator goggles are all I need for basic FPV, well that and a couple charged batteries but you get the idea.
So here's the total of what I need to bring along, makes it quick and easy to get out and do a little FPV flying without having to lug a bunch of gear, if I want to get more involved I have the MK quad with OSD and some other goodies that requires bringing along more "stuff"...
F 450 plus Dominator goggles the basic FPV gear...
A closer look at the goggles with Bluebeam antenna, I also have the shorter version that mounts straight out from the front, tested it this morning and it seems to work just as well as the right angle mast antenna...
The Dominator carrying case, about time they included something like this...
A look at the camera on the front of the F450, held on by double sided super sticky servo tape and a couple small tywraps for good measure, solid enough to not be bouncing all over in flight and soft enough to break free in the event of an encounter with mother earth, hopefully preventing damage to the camera...
The Immersion video TX, I was a bit surprised to find the 100 mw unit is substantially larger than the 600 mw unit I have on the MK quad. The power is via a cable soldered to the connection points on the DJI lower frame plate through a JST connector set so I can unplug and swap the TX to another multi without having to desolder anything. Just as on the MK FPV quad it has the Bluebeam clover leaf antenna, the difference between the old 200 mw cheapo system with rubber duck antennas and this system is night and day, crisp super clear video and it records far better over a downlink as well. The antennas alone made a big improvement on the old gear, with the new electronics the system is huge step up from what I had before...
Everyting has been debugged and thoroughly tested, tomorrow AM I'm off to the flying field to try out the new gear where I have plenty of room to play, video to be posted afterward.
