2tall
Fly Often - Fly Safe
I just finished the build and install of an AeroXcraft GoPro gimbal. I'm using two Hitech 5065MG servos along with the Naza gimbal gain and speed controls. I have upgraded to the latest Naza firmware and have set the Gimbal HZ output to 200, the spec for the Hitech 5065s. The servos are not nearly as smooth as I thought they would be. The jerkiness is clearly visible as the servos work to keep the camera in position. AeroXcraft recommends powering the gimbal servos at 6V using a UBEC. I have not done that yet, but will in a couple days when I have the F550 partially apart for other reasons. (FPV/OSD stuff is arriving - yey!) Will the switch from 4.8 to 6 volts help smooth the servos? Is the jerkiness the nature of the beast and as good as at gets at an inexpensive level? Is there some other fixable cause that I have overlooked?
Thanks,
Jon
Thanks,
Jon
