I am getting mad with you as well.
Have you bound you receiver to your transmitter as per the manual?
Link to the transmitter
Easy Link ID allows FASSTest receivers to link to compatible
transmitter without pressing the link button on the receiver.
1 Bring the transmitter and the receiver close to each other,
within 20 inches (half meter).
2 Turn on the transmitter. Place the transmitter into the receiver
linking mode.
3 Turn on the receiver.
4 The receiver will wait for the linking process to begin for 2
seconds. Following that it will return to the normal operation
mode.
5 When the LED of the receiver changes from blinking red to
solid green, linking is complete.
(A link waiting state is ended in 1 second.)
• Refer to the transmitters operation manual for complete details on how to place the
transmitter into the linking mode.
• If there are many FASSTest systems turned on in close proximity, your receiver
might have difficulty establishing a link to your transmitter. This is a rare occurrence.
However, should another FASSTest transmitter/receiver be linking at the same time,
your receiver could link to the wrong transmitter. This is very dangerous if you do
not notice this situation. In order to avoid the problem,we strongly recommend you
to double check whether your receiver is really under control by your transmitter.
• If the System Type of the transmitter is changed, the receiver will need to be relinked
to the transmitter.
Have you installed the USB drivers for your PC?
Assistant Software Installation and Configuration
Step1 Software and Driver Installation on a PC
1. Please download the drive installer and the assistant software installer from DJI website “
www.dji.com”,
by selecting the Download web page of corresponding product.
2. Switch on the transmitter first, and then power on the autopilot system.
3. Connect the autopilot system and the PC via a Micro-USB cable, and power on the autopilot system.
4. Run the driver installer, and follow the instructions strictly to finish installation.
5. Run the assistant software installer, and follow the instructions strictly to finish installation.
