Flying a F550 with NAZA/GPS and a 2.4 mhz radio. After I get satellite lock (green light flashing), I power up my FPV xmitter (1.2mhz) and I get 3 flashing red lights along with the green light which indicates I have less than 5 satellites. I've moved the xmitter all over the 550 and most of the time I still get the
3 red/1 green lights. Once in a while I find a place that I only get the green light, but it might switch back to the 3 red/1green at anytime. I'm pretty sure the xmitter is interfering with the GPS antenna, because I can shield it (GPS antenna) with a piece of aluminum foil and it works find, except it's not practical to do so while flying. My question, would it be better to go to a 5.8 system or will I just run into the same issue? Tried with and without a low pass filter. Might my 1.2 xmitter be faulty? I've also used a separate battery to power the xmitter.
