Yeah I know about the different osd options and sizings on the NEX5n, suppose it isn't really a problem in real life.
I have it figured out on how to connect everything without iOSD, thanks to
this helpful thread. I have the HDMI to AV converter.
However, when I try to put everything in a diagram for using it with the iOSD, it is the DJI manual that is confusing. It has something to do with the voltage, just like Kloner said.
My wireles vTx is powered by a 3S lipo, 12v. That is what the board is rated for.
I have a yellow cable for video and black from ground going from the HDMI2AV board to the iOSD. I power the HDMI2AV board from the HDMI cable, so the following warning in the manual is not for me. Correct? So, from the iOSD input port I only solder AV1 and GND.
DJI Manual said:
If you use your own camera(s), please connect through the Video Input Cable according the pin description.AV1/AV2 pin:you can select the required input. AV1 is default. POWER pin: supply power for Video input
source such as a camera, with the maximum current of 1A. If the battery is 3S LiPo then: Output Voltage = Input
Votage. If 4S~6S then: Output Voltage=11.2V. Make sure your camera is rated for this voltage and
current(1A), if not, please use a separate battery supply.
· If you use other wireless video transmitter and the rated voltage is over the voltage of BATT+, you can use the
POWER pin to apply power. Make sure the total current consumption of wireless video transmitter and camera
is lower than 1A, otherwise will damage your iOSD.
Then from the iOSD to the vTx, I use the one port cable connection for making your own connection to a non-DJI vTx cable. This one has 8 wires running from it.
Here is where I am confused big time. What goes where? I only have a 3 pin input connection on my vTx.
And then there is this warning
DJI Manual said:
Please make sure the input voltage of your own wireless video transmitter is matched to the voltage ofBATT, to prevent damage from your wireless video transmitter module. For example, if the Battery is
6S(25V) and the input voltage of the wireless video transmitter is 3S(12V), then you cannot use the
BATT+ to supply power since the 25V is larger than 12V.
My input voltage is 12v, 3S lipo. With BATT I suppose they mean the flight battery to where the iOSD module is connected with, this is a 4S lipo, 14.8v. Is this where the dollar regulator comes into play, I lower the voltage from 4s --> 3s?
How do I then go about wiring everything up in my vTx?
Code:
Negative voltage of battery(=BATT-) ____________ dollar regulator___12v___negative power wire vTX
[COLOR=#ff0000]Positive voltage of battery(=BATT+)[/COLOR]_____________dollar regulator___12v___positive power wire vTX
[COLOR=#ffa500]Channel Control[/COLOR]_____________________________Will not use
[COLOR=#8b4513]Video GND[/COLOR]_________________________________Solder to black
[COLOR=#ffff00]Video and OSD output[/COLOR]________________________Solder to yellow
Hope it is somehow understandable, not easy for me to explain or to understand
Any of your expertise is a step forward for me
