lol i will use a small FPV cam but not for FPV... i want it in order to help me when i am doing my job..! thats all..right,,, so what cam do you want to use for it?
i am doint that and i have an operator for the cam ...!So, you cannot use the cameras output to frame what you are filming? That is was many of us do.
I dont want it for FPV .. I use the copter for Aerial Video/photography..!
I want to put on more cam on the front boom and an lcd in order to see the OSD and also to fly via the lcd when its to far from me..
I believe what you asked for is called FPV---First Person View. Not sure why you refuse to acknowledge it. From Wikipedia:First-person view (FPV), also known as remote-person view (RPV), or simply video piloting, is a method used to control a radio controlled model vehicle from the driver or pilot's view point.
No reason you can't put a camera on the front of your MC, downlink it's image (including OSD) to a ground station, and view the image on an LCD. When shopping for the components to do that, you'll probably have to look under the heading of FPV, regardless of what you want to call it.
Jack
I think I do. . . . A "fpv" set-up will give you the orientation you are looking for at long line of sight distances. . . sayyy 200meters?Lol... My english are not good and that why you cannot understand me..!
Guys the FPV is for me(the pilot) in order to help me with the flight when i want to see via LCD...! Do you understand me..!
Yeap that helps..! i think it will help me as you say at long line of sight distances..! but do anyone use it??I think I do. . . . A "fpv" set-up will give you the orientation you are looking for at long line of sight distances. . . sayyy 200meters?
It can "guide" you to framing your "shot" as well but that "framing" will not be very accurate as the lenses of the "fpv" cam and the AP cam are most certainly different.
I hope that helps.
Check this outYeap that helps..! i think it will help me as you say at long line of sight distances..! but do anyone use it??
OMG... ok its FPV but will it help me to AP AV>..!
I try to tell you that i wont go too far etc..! I wont use the copter for LONG FPV flights...! but only for AP AV jobs!
