Hello experts,
I've been rocketing around in a Hubsan X4 H107c for a while now and am now ready to upgrade to a big boy quad. Instead of purchasing one of the fine RTF models out there I decided I would like to try my hand at building my own. I happen to enjoy huddling over my workbench, burning my fingers on a soldering iron and practicing my profanity. I've spent quite a bit of time researching and have come up with the following build list. Please feel free to mock and/or give suggestions.
My goals:
- FPV
- Good endurance
- GPS stabilization/Waypoints/RTS
- Affordable
- Somewhat transportable
I have:
- GoPro
- Misc electronic equipment and supplies
What I'm looking to buy:
Bird
- 9332000005 - Turnigy Integrated PCB Mini-Quad 345mm (Removing the airplane design)
- 9351000006 - Turnigy Multistar ESC Programming Card
- 9351000003 - Turnigy Multistar 20 Amp Multi-rotor Bru
- 387000041-0 - Case Set For MultiWii PRO Flight Control
- 387000003 - MultiWii PRO Flight Controller w/MTK GPS
- 9192000114-0 - Turnigy Multistar 2209-980Kv 14Pole Mult
- 9329000027 - Slow Fly Electric Prop 1045R SF RH Rotat
- 9329000028 - Slow Fly Electric Prop 1045 SF (4 pc - G
FPV
- STCR351305 - SkyZone 5.8Ghz 200mw FPV Wireless AV Tx
- 435000015 - 5.8 GHz Circular Polarized Antenna SMA
- 9171000444-0 - Quanum DIY FPV Goggle Set with Monitor
- 9074000220 - Hobbyking G-OSD 3 Mini OSD System w/GPS
- 258000115-0 - Super Slim GoPro 3 A/V Cable And Power L
- 258000112-0 - GoPro and AEE Magicam Live A/V Out FPV C
Misc
- TX-9X-M2 - Turnigy 9X 9Ch Transmitter w/ Module & 8
- 258000011 - 10CM Male to Male Servo Lead (JR) 26AWG
- 12V45AUBEC - 12V 4.5A UBEC 2-5S Lipoly (7.2-21V) (Adding LED's)
- 258000070 - JST-XH Parallel Balance Lead 3S 250mm
- Voltage-Alarm - Hobbyking 2-8S Cell Checker with Low Vol
- AM1001A - PolyMax 3.5mm Gold Connectors 10 PAIRS
- AM1003A - 4mm Gold Connectors 10 pairs (20pc)
Battery
Multistar High Capacity 3S 4000mAh Multi-Rotor Lipo Pack
eCalc gives me a hover at approximately 52%, but I've struggled to find a configuration that will give me over 10 minutes. Right now I'm hoping to use the GoPro as the FPV source, but eventually I would like to add a separate camera and attach a gimbal.
Let me know if I've make and glaring errors, or if there is a much better, similarly priced build I could make.
My goals:
- FPV
- Good endurance
- Affordable
I have:
- GoPro
Bird
FPV
Misc
Battery
