On my Jeti receiver in PPM mode, the receiver shuts off the signal (not 0%, but OFF) if connection to the transmitter is lost. The Naza goes into failsafe mode when the signal is shut off, but I have two questions regarding this:
1) I have read that the throttle signal should be 50% (at least significantly more than 0%) in failsafe mode. What happens if the throttle signal disappears? I guess this will be similar to a PPM cable connection failure
2) What happens in failsafe mode if the throttle signal exists, but is 0% Will the copter fall down immediately, or will it fly towards home for a little while and then fall to the earth?
