yes it will pull more amps, but that's the idea as you get heavier is to up the props so your manual hover is near mid stick. when the props don't do it, you add more volts, then that's not enough, needs bigger motors.
in general, the recomended prop/cell counts are for a bone stock nothing but f450....... add stuff, needs uping the power
Your twitch increased with the smaller props?
I went down to 9" props to get the smoother flight on my set-up
