with the ezuhf on 8fg you will need to do a couple things. Pry the futaba trainer connector apart and get the +vcc wire clipped, i pull the pin right out of the connector. then on any dji controller, you need to set all the sticks and switches to middle possition and bind the rx..... then put in a dji product and set it up like normal and reset bind but use just under half way on the throttle instead of anywhere over 10%..... naza looks for center pulse when booting or something like that
In any software interface you'd want to look over the stick inputs, calibrate the radio to it
I've never had any problems like Bart has had, why i don't know what to tell him. it's like he has different firmwares or just a malfunctioning part
I have win 7 and another pc uses win before this, all 64 bit. My friends run apples and parralels, works fine there..... never not seen the software work either
