John Doecliff
If your charger has a "Charge till" function then yes set it at 12.6 but I have never heard of that kind of charger. Thinking maybe you should post a pic of the charger and not the quad. LOL
Unfortunately, it's not. I just finished charging a bat (LiPo Balance, 1.3A, 11.1v 3s) and it charged until 11.18v. I'll stick it on again as long as that's not too dangerous.12.6v when fully charged
You need to let each cell charge to 4.20v. That will be 12.6 at full charge. You need to start off your flights with a full charge. Your charger if it is a good one will have different charging rates. The charging rate is how many amps you are putting in to your battery per hour. More amps = less charging time. Sounds like yours might be set at a real low rate. When it is set to charge slow, that is exactly what it will do....charge slow.So, when the battery is charging, if I tab over it says that the end voltage will be 12.6. However, it doesn't ever get there. I've charged it from 10.2 to 11.1, from 11.1 to 11.21, and now from 11.21 to 11.3v.
