Balmybaldwin
Hello, I'm new here (and to flying MRs)
Currently running a DJI F450 with Naza M V2 & GPS, and learning to fly it LOS (and will be for at least a few months), but my long term plan is to go fpv, so I'm starting to do my research into what I need. (I'm also not sure that I won't build a custom frame that is more easily transportable, but that's another question entirely - my point is that I'm treating the dji frame is just a starter frame)
It seems as ever to be no end of different suppliers/specs and combinations available... from "starter kits" with vTx,vRx,monitor etc included to individual items. What should I really be looking at in terms of specs (i.e. what's important?)
What are the advantages/disadvantages of goggles over a screen?
I read that of the various frequencies for vtx/vrx 900mhz tends to suffer least from interference in terms of transmitting around trees, buildings etc Is this right? Is there much difference? Is vTx power more important? As I'm using 2.4 Ghz for my main Tx and have GPS, am I right in thinking that the only frequencies available to me are 5.8Ghz and 900Mhz? (Also I'm UK based does that change what I can use?)
Whilst I want to do aerial photography and FPV, I'm not convinced I want my GoPro to be my FPV camera, and would rather keep this for filming, as I'm guessing the tx/rx process will either need to be expensive, or to transmit a much lower resolution that I would want to film in? Also, I'm likely to want to film to the side rather than straight on, and it will make life easier if I don't have to fly sideways to film a subject. To that end I'm thinking I want a small security type camera for FPV view, before adding a seperate gimbal mounted main camera (possibly operated by a second operator). Does this sound like a good idea?
Ideally I would like quite a lot of redundancy in transmission range for the video feed (i.e. a range greater than my Tx provides) so if it goes out of range and auto lands/plumets from the sky I still have a video feed to locate the drone/pieces more easily so what kind of vTx power should I be looking at (I'm running a 2.4Ghz Devo 10 tx)
For those that are UK based, who are your favourite suppliers of bits? do you buy UK or import (and do you get hit by tax?) prices seem much better in the US
Many thanks for your help folks
