just to comment, uhf 433 antennas are all the same. monopole, bipole, just matters what kinda range your looking for. one thing i learned a few times now is if you make an antenna make sure to get it covered right and get a cap on the top. if you fly in dust and static builds up the end of that antenna will discharge static to the rig and usually short it out.... you want it mounted so it can be los to you as much as like your video antennas.... they should all be seperated as far as possible and be pointing up or down not laying flat along carbon fiber plates or tube. Idealy and why fpv specific use g10 is for rf transparency, a disco with plastic arms has 100% killer signal and nothing really matters how anything is mounted, but boy, get that same gear on a skyjib and throw in cf props and here we go,,,, signal, yaw a little and no signal, yaw a little again and signal is back... pita
a foam wing is the ultimate, major seperation between systems and foam so no rf blockage,,,, even the rods inside a fpv wing are glass and not cf for the same reason,,,, so don't rely too much on the system being major long range using it in a cf frame if it is
i tried dl on a jr11x and had crazy ppm drift issues.... i'd setup a rig, go fly for a while, then one time i'd hit the wrong switch and my ppm would change the widths i guess to fake 11 channels in jr modulation, but that dragon link dam near tried to kill me. be careful. if you notice stuff crashing like i did, stop using it immediately, it's not you.... i had three models in the dirt in a few days till i realized it was hapening
