ESC'S may be my problem
this is no more complicated than clicking the X config in the proper tab under configuration. i have a sport on my X quad. cant be any easier. Just make sure you save it, have your esc's/props on right. Check it without props first. The setting has nothing to do with your radio.
I have a CHEAP set of ESC'S on my copter, and basic ESC Programming, but no info on proper ESC Setup. Number of beeps is One, Two, Three
_,_ _,_ | _ _,_ _ _ _,_ _ | _ _ _,_ _ _ _ _ _,_ _ _ |
Only problem is, no way to tell what programming your in, and no real manual for programming. Each set of beeps is a Toggle I believe, between to limits, but I can't seem to tell by how the motors react except for the break.
Anyway, I got a New set of ESC's coming, Hopefully they will come with Precision Programming instructions. Not same esc's, a better brand, and all four.
Also, as I stated, I need to know the correct programming of the radio. If the setup of the radio is not right, nothing will be fixed by replacing anything.
