View attachment 14317A couple of thoughts.....
I have the same DJI 5.8Ghz video downlink and am getting over 500 yards clear signal at a rural golf course. However....
I am using a diversity FPV monitor/receiver system as follows:
http://www.hobbyking.com/hobbyking/...CD_Monitor_for_FPV_800x480_LED_Backlight.html
Also I am using the Fatshark cloverleaf antennas, one on xmitter and the other on one of the FPV built-in receivers. The other receiver simply uses a conventional omni antenna.
Also my 5.8Ghz video xmitter is mounted straight down as per DJI instructions, and as far as possible away from other electronics on the MR airframe which, in my case, is an 800mm airframe such that I have a bit more room to move it around.
Also I use the following to maintain some distance between the FPV receiver antennas and the RC transmitter antenna.
I'm using the DJI 5.8 downlink system that came with the S800 EVO package and my picture on the monitor is real poor quality. I pick up the signal on channel #3 on the receiver. Only channel from 1 to 8 that receives picture. I have a 1.2 system on my F550 and it works good using the same monitor. Any thoughts?
