Welcome To DroneVibes
DJI S1000 horrible jello - help needed
Discussion in 'DJI A2 & WKM flight control systems' started by konibak, Aug 18, 2014.
  1. gtranquilla
    gtranquilla RadioActive
    Posted by gtranquilla, Aug 18, 2014 #21
    Caution:
    Motor and/or prop vibration can cause erratic MR behaviour leading to a crash........ depending upon magnitude and frequency of vibration and your FC-IMU system to tolerate vibrations.
  2. econfly
    econfly Member
    639
    189
    0
    Sep 2, 2013
    Posted by econfly, Aug 18, 2014 #22
    I would start by backing off the prop screws a bit. My guess is the props are too tight.
  3. fdproductions
    fdproductions FD Productions
    134
    0
    1
    Mar 8, 2014
    Los Angeles
    Posted by fdproductions, Aug 19, 2014 #23
    konibak,
    1. please please don't treat this issue lightly.
    2. if you can visibly see one or TWO or your arms flexing or acting funny land immediately.
    3. when was the last time you changed your lock knobs (S1020301?)
    4. do they all even have an audible click still?
    5. have you replaced damper units on the motors between regular intervals?
  4. konibak
    konibak Member
    14
    0
    0
    Aug 17, 2014
    Posted by konibak, Aug 19, 2014 #24
    The s1000 is brandnew, has maybe 2 hours of flight. I didn't changed anything. All the lock knobs have an audible click.
  5. konibak
    konibak Member
    14
    0
    0
    Aug 17, 2014
    Posted by konibak, Aug 19, 2014 #25
    Do I have to remove the white threat lock on the prop screws ? How? By warming up ? Didn't have a burner...
  6. econfly
    econfly Member
    639
    189
    0
    Sep 2, 2013
    Posted by econfly, Aug 19, 2014 #26
    No. Just back them off slightly. The prop should not wobble, but be loose enough to move very easily.
  7. konibak
    konibak Member
    14
    0
    0
    Aug 17, 2014
    Posted by konibak, Aug 19, 2014 #27
    My props are moving with very "tight" resistance. I'll try to loose them. Thanks!
  8. Tahoe Ed
    Tahoe Ed Active Member
    2,064
    27
    31
    Sep 14, 2011
    Posted by Tahoe Ed, Aug 19, 2014 #28
    The proper setting is .4nm of torque.
  9. konibak
    konibak Member
    14
    0
    0
    Aug 17, 2014
    Posted by konibak, Aug 19, 2014 #29
    Thanks. Unfortunatelly don't have torque wrench :/
  10. econfly
    econfly Member
    639
    189
    0
    Sep 2, 2013
    Posted by econfly, Aug 19, 2014 #30
    Don't worry about it. 0.4Nm is a very low value. A little dry loctite in the threads can have a material impact on the measurement. You can do this by feel. Pick the aircraft up and rotate it so the props are perpendicular to the ground. They should hold position (motors may turn -- that's fine). If they flop down to point to the ground they are too loose. You want them just tight enough not to do that. (just my opinion)
  11. Tahoe Ed
    2,064
    27
    31
    Sep 14, 2011
    Posted by Tahoe Ed, Aug 19, 2014 #31
    You must be an old heli guy as well.
  12. konibak
    konibak Member
    14
    0
    0
    Aug 17, 2014
    Posted by konibak, Aug 22, 2014 #32
    I've tried to losen the prop blades a little bit as adviced. No visible result, jello still present.
    Today I'll try to tighten the motor dampers, maybe add washers...
  13. econfly
    econfly Member
    639
    189
    0
    Sep 2, 2013
    Posted by econfly, Aug 22, 2014 #33
    If it were my problem this is what I would do.
    First, log flight data for each ESC (if you are using a DJI controller, get an iOSD Mk II). Maybe you can see where one or two arms are either running at odd power levels, oscillating, etc.
    Second, just check everything including balance. Be completely sure that the rig with everything installed is as perfectly balanced as possible.
    Make sure the gimbal is balanced as well, and check yaw balance in addition to pitch and roll (pick up the copter, turn it 90% so the gimbal yaw axis is a balance point, and make sure that the gimbal doesn't want to rotate one way or the other around that yaw axis).
    Check screws and look for wobble or movement on each arm, motor mount, prop mount, etc.
    Check the gimbal attachment points. Look for loose screws, binding or tightness that shouldn't be there, etc. The rubber dampers should flex and absorb movement.
    Check the camera to gimbal mount. The camera should be solidly and securely mounted.
    Fly it. Check the logs. Compare ESC/motor output. Look for an outlier. If you find one swap it with an opposite arm. Fly again. See if the problem follows the bad arm. If it does, replace it or tear it down and build it back checking everything on it. If the problem stays in the position check the contacts at that position (electrical and mechanical).
  14. Rasec
    Rasec Member
    12
    1
    0
    Sep 27, 2012
    Brazil
    Posted by Rasec, Nov 5, 2014 #34
    The problem was solved? I now have the same problem
  15. SleepyC
    SleepyC www.AirHeadMedia.com
    1,709
    342
    66
Loading...
Share This Page
Loading...
