DJI Ground Station for PC - huge WP labels
hover.ch
Moving from one to another PC I'm facing a big problem with big fonts.
All labels for waypoints and waypoint distances, overlays on Google Earth background, suddenly appear huge.
I'm using a 3200x1800 13" display. GS version is 4.0.9.
Any idea what's wrong?
your computer looks like you have the fonts setting increased.... go to start, control panel, appearence and personalization, fonts and make that setting "normal"
rilot
It's because you're using such a high resolution display. The DJI program hasn't been coded with hi-dpi displays in mind and so goes spaz.
The only thing you can do is change your display scaling but this will have the effect of making everything else tiny.
Swipe in from the right edge of the screen, and then tap Search. (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.)
In the search box, type "text".
In the search results, tap or click Settings, then choose Make text and other items larger.
Under the option Change size of all items, select Medium (125%).
Tap or click Apply.
Choose either Sign out now or Sign out later to apply the new setting.
