PeteDee
Mr take no prisoners!
Onestop,
As you stated the connections are “pretty good”, which easily implies “not good enough”, especially for an integral and important component such as the GPS. The unit I received only has one end of the supplied wire with a “clip” to secure it into the Flytrex unit. The NAZA GPS unit B A R E L Y even holds in with its own tension, FAR INSUPERIOR to what is actually required.
My opinion is based off my own, first hand use, not swayed by anything such as a “bottom line” of the accounts ledger. The unit needs to be improved and a way for the GPS wires to be secured PROPERLY.
Did I contact Flytrex or my dealer? No, why should I? Why should I keep this obvious problem under wraps so retailers can continue to sell a flawed product?
I currently have the GPS antenna wire taped into the Flytrex and will give it a try again, and even with this design, it’s not “tight”. It is my intention at the first indication of GPS malfunction that GPS/ATT switch is getting set to ATT and it’s coming home under my own control. Flytrex should NOT be considered “safe to use” when you wish to have a “Fail safe” mode with your NAZA. At this point, when the Flytrex installed I consider my Naza a “With-out RTH” device (due to the Flytrex).
The simplest solution would have been a “T-Connector” that fed BACK into the Flytrex, not THROUGH the Flytrex.
Don't get me started on being REQUIRED to use Facebook to sign into their website to upload/use the device... Their solution was to create a "blank" account just to log in. (blatant disregard to FB's policy).
Corey
Hot glue is your friend and has always been the heli flyers friend.
