DJI 30A Opto Esc's vs Discovery Esc's
that is the core. You can steal 5volt to a cam off the immersion, but i'd put that cam on the core for power, run it through the osd, then the vtx on the flight pack, your golden
JG-rn
Ok so I will put the cam on the core, and the Vtx on the board. Do I have to worry about noise interference with the Vtx on the board? I thought the noise issue was why it was good to run it through the core?
just ordered the disco, short servo leads, core installed, tin shield. One of the options was a 100a current sensor. I don't need that right?
JG-rn
Btw, I have a cam on order from RMRC. The 600 XV NTSC.
Im wondering if I should cancel that and get the tbs69 cam or one of the Pixam cams.
Would the difference be noticeable ?
EDIT: ordered the tbs69
JG-rn
As for ESCs, I can't say about the TBS ESCs as I don't own any, but I do own a couple sets of DJI and many sets of SimonK flashed DYS and HK Blue, the SimonK ESCs are by far much smoother and easier to dial in the gain settings with. The DJI work OK with a Naza as long as you have the right size props for the motors and RTF weight plus the gain settings dialed in, but there is a noticeable positive difference when switching to good SimonK flashed ESCs.
Are these the DYS simonk esc's you were talking about?
http://www.quadroufo.com/product_info.php?cPath=2_6&products_id=37&osCsid=h9ire397helff5pqm3kipco0e1
EDIT: ended up ordering the dys simonk flashed esc's
