whoisthedaddy
150th Member!!
All,
What a great site, so many useful threads and posts. After reading many of these over the last few days I wanted to share my thoughts so far for your comments and advice. Before I go into the details and reasoning I think it worth mentioning that my personal requirement is for a craft that is capable of taking professional quality aerial video. (I am not interested in throwing it around the sky aggressively). Due to the commercial nature (I hope!) I need the craft to be as resilient and fail safe as possible and be capable of smooth and reliable flights - If something doesn't work on a customer site ideally it would be possible to repair without a complete strip down - I don't want too much!!.
Primarily due to the safety aspect I have decided on an Octo configuration (I like the Droidworx AD8HL frame) for three main reasons:
The Hoverfly Pro supports external and individual ESCs which although they need calibrating individually I still think I like the idea of for a number of reasons:
Although I haven't really started yet on deciding on motors / prop combinations I have already read a lot of posts on these topics and I'll post again when I've read them properly.
Any advice or thoughts gratefully received and thanks in advance.
Lee.
- A numbers thing, the effect of 1 motor failing out of 8 will be less than 1 failing out of 4 and hopefully the craft can be landed safely!
- A mass thing, 8 motors weigh more than 4 motors (not to mention the additional battery weight and electronics) and this mass should make the craft more stable (less responsive?).
- My thinking is that the additional thrust can carry additional weight (e.g. video camera, transmitter for FPV (future) / GPS modules (future too!)
- It comes pre-assembled! - I am not a fan of soldering.
- It seems considerably easier to use - there is little programming as such.
- It looks like it has all the functions I require with GPS in the future (I've read the posts but this is not urgent for me)
- The external wiring connections look very neat, they are also plug in as opposed to solder in which means an easier and quicker change in the event of a problem).
- Safety, if one fails the others still work!
- They can be located on/under the airframe (as opposed to in the dome) and therefore 'air-cooled' as opposed to some systems which need their own cooling fan.
- They are easily changeable - the MK ones are built into a frame and the motor wire soldered directly to them
Lee.
