Castle Creations Speed controllers with WKM
sim_io
Any idea what the thermo shut out temp is?
Did you have to do much programming to set them up or where they straight forward?
is 130ºc as hot as they have been? Was you copter fully loaded, what was the outside temp?
130 Fahrenheit = 55 Celsius ;), a quick google search said that these CC ICE 50 escs shut down when the internal temp reader marks 250 Celsius but its better to keep them below 210 C.
Programming the ESCs was straight forward, what I did was upgrade them to the 4.01 firmware, set the multicopter option, timing to low and refresh rate to 12 other similar settings are ok too.
The whole CS8 weighs 5.5kg or 12 pounds with the 2-axis gimbal and a gh2 using a 4s6000 but I plan to use two of these in parallel because flight times are nearly 5 min with 11x4.5 props.
ChrisViperM
CC stuff used to have a few issues....but in the meantime they sorted it out...and now their products a pretty reliable.
Chris
