mbsteed
aerial video centric
I took my Hoverfly Pro setup out for a bit of test with my Canon Vixia G10 on a MKTR Pro Gimbal and the footage was really jerky. It was not the jello you get from motor vibrations - I have two levels of vibration dampening between the frame and the gimbal (one level of sorbothane). I have gotten smooth video in the past. I got thinking about this and decided to do a bench test and noticed one of the servos was quite noisy. The servo in question is a Hitec HS 7985MG for the roll. I felt the camera with my hands and you could literally feel the vibration coming through. I happened to have a spare 7985 so I took the gimbal apart and replaced the servo and all is good again. I have the servo directly connected to the Hoverfly Pro board. My question is why would an expensive servo like this go bad (I have probably been using it for just over a year - not even used once a weekend). Do I need something between the servo and the Hoverfly Pro board?
I suspect many folks fight with vibration dampening when really the problem is jerky servos.
