jfro
Aerial Fun
Just looking to verify what I understand are a few basics about charging lipos. I'm hearing lots of warnings and have decided to look for some guidance on the charging of lipos.
I am starting with four 5000mAh 4s batteries. 2 are 30C and 2 are 40C. Max charge rate on both is 5C. I'm trying 2 different brands to see if there is much difference.
<colgroup><col width="86"> <col width="86"> <col width="277"> <col width="86"> <col width="206"> </colgroup><tbody>
</tbody>
I purchased a iCharger 306B charger with a paraboard with deans connectors. I've switched to EC5's so I assume I can just use deans females to ec5 male extension of 1-2 inches or just buy a new paraboard. I have a converted 550w 28amp computer power supply for now and will probably stay at 12 volts. May upgrade to little bigger power supply, but for now this will suffice.
Some say to charge lipos at maximum rates shortens the life of the batteries. However, some seem to think that with a good charger, this is not necessarily true any more, at least for the batteries. I've also read where some say power supplies and chargers will work better and longer if you stay a little under their maximum ratings. Any opinions?
Is it good practice to first discharge a new battery and then charge it fully to get a baseline on what you batteries full capacity is. Do most people do this? If so, do I have to hook up a regular 12 volt car battery as the power source to discharge the lipo with the 306B?
I have scanned through the 306b manual a couple times and watched a couple you tube videos. I'll do my first charge on a single battery in the next couple days so will know more after that. Looks like there are lots of settings that I won't use in the beginning. Pretty confusing for a first timer.
I read something about quick charging does not charge the lipos 100% because the last 10% or so takes longer as that's done at more of a trickle charge rate to top them off. Out in the field, peeps usually forego that last 10% so they can quick charge and get back to flying. Is this somewhat accurate?
If this is the case, can some tell what settings I need to set for quick charge vs a full charge and are there any longevity issues on doing it either way?
| | watts | amps | Charging time in Mins |
1c | 84 | 84 | 5 | 60 |
2c | 84 | 168 | 10 | 30 |
3c | 84 | 252 | 15 | 20 |
4c | 84 | 336 | 20 | 15 |
5c | 84 | 420 | 25 | 12 |
</tbody>
