I'm gonna be building my charger case and wanted to share with you guys. this is a pair o the dell 700 watt 12 volt server power supplies modded and ran in series to make 1400 watts at 24v, around $30 invested in them. makes a 1kw charger run all of 1kw. it seems to run around 1200 watts, guess the extra is lost in efficiency and overhead. The case is a pelican clone 18"x14"x7" and costs $60 to your door. am using teak 1/4" ply from lowes cause it was there cheaper high grade stuff. the foam on top is from Hydro Turf but is just there liner for putting under HT flooring like in glass and metal boats/jet skis.
should be finishing it up today so will keep adding pics as the day goes. there is a 9mm foam pad that goes over the wood that makes the charger and charging board sit flush with the surface. i'll be transporting the batteries in there too when were traveling. it is so heavy already
