Old Man
Folks
I'm reaching out for any info I can get because I'm at a complete loss for ideas and DJI has fewer to work with that I do. They tried hard but no joy.
I'm in the final stages of setting up a new A2 controller and running into some problems. The initial software was v2.1 and the DJI Assistant recognized the controller, no problem. The next couple of items are when connected direct to the A2 via a laptop. I have not done the app install on my i phone. The Futaba TX and the controller have been linked successfully.
Today I tried the v2.2 upgrade and after exporting the parameters from the 2.1 version, when attempting to import to the v2.2 Assistant the Assistant fails to recognize the controller is present and rejects the import. However, it will enter, but not complete, the calibration mode in the "tools" menu. Due to this I reverted to the 2.1 software. For those wondering if the motors will arm, they will do so with either software release.
Earlier, using the 2.1 software, the A2 would not recognize the presence of a battery when attempting to set the voltage limits and fail safes. That eventually came together after reloading the A2 Assistant but the controller will not permit calibrating the compass and GPS. After establishing that the modes change accordingly in the Assistant when flipping the mode switch the most I have been able to get out of the LED indicator is a constant series of red flashes. Earlier, when I was having issues with battery recognition I would get a long series of yellow flashes, changing to a long series of red flashes, which combined with the inability to establish voltage limits led me to believe there was a battery recognition issue. Now the yellow flashes are no longer involved, the voltage limits are set, but I cannot calibrate any of the directional/positional hardware-software. The quad is set in the middle of a yard, no physical restrictions blocking the view of the sky/horizon, with no metal or electromagnetic items with 20 feet of the quad.
I've gone back through all the connections and found them good. Disconnected the 2.4Mhz data link with the thought there might be a frequency conflict with the 2.4 TX. Battery has at minimum been at 25v for all the attempts, and a volt meter confirms at least 24.9v is present at the controller XT-60 power input. Channel mapping is complete and verified via the A2 Assistant. I've tried calibration with the fail safe switch in both normal and "Go Home" positions with no joy. Even tried all the possible positions with the IOC switch involved in the process.
The DJI voice help line doesn't have a clue, and in as much said they know very little about the A2. They suggested contacting the selling vendor for a replacement. Hopefully the above is a good informational starting point for someone that knows the A2 to provide some thoughts with. Thanks.
