i love nachos
I am very familiar with balancing props. What I am looking for is some advice on diameter and pitch. For planes I alway split the diameter to get pitch. I just dot know what the happy formula is for a hex.
At the same prop speed and diameter the higher the pitch the more amps drawn.
For slow flying and hovering use the lowest pitch and largest diameter you can for torque and efficiency.
For fast flying/acro the higher pitch is more dynamic has a higher top end speed.
There is also the issue of weight, and prop blade design, KV, etc.
The thin prop is, well, thinner which means it doesn't have as much torque as a fatter blade SF.
It's heavier, so there's more load on the motor to spin it.
If the pitch doesn't match the KV you can get magic smoke.
Like so many things, it just depends on what you want to do.
Have you checked the tracking on all of them?Well these, after 4-6 hours of balancing and centering are stil making my arms jump around like I was missing a blade!
why are xoar hard to balance. 1min max with 1 prop and sandpaper. the best and easyest prop ever. we have them all in shop and we always use xoar. Maybe your method off balancing is just not that simple or you balance them too much.That's what I wanted to hear. Thanks! Seems everyone is sold on Xoars, which may be the bee's knees when balanced. But they are hard to get, expensive and take a good amount of balancing. It will be interesting to see how a 12x6 thin compares to a 12x3.8 slow fly.
