Photronix
Pilot
Couple things.
First yes you can enable AH and AL in flight.
Second, upgrade your firmware on both the PRO/GPS to 4.3.802 and set your AL smoothness to 10%
Third, the HoverflyGIMBAL is working extremely well. Honestly, the only limiting factor at this point are the Potentiometers on the Photohigher gimbals. The video below shows the AV200-360 using Magnetic hold. The video would be much better with a better gimbal. The poteniometers suck. The PhotoShipOne 3x is amazing and the HoverflyGimbal works great WITHOUT pots. This firmware will be available next week.
Fourth, the HoverlfyGIMBAL is $360 and available now. You do need signal conditioners in the first version of the board (~$15) to use it with the unlabled unknown servos used on the cinestar gimbal. The next revision of the board does not require them. So $360 is pretty amazing we believe because you will have pan compensation. The Photohigher RSGS does not have a magnetometer and can never utilize pan stabilization using magnetic hold.
http://www.youtube.com/watch?v=L6WJJAmefkw
