Hey Dan thanks for looking into it, Seems that when you guys updated the firmware client this afternoon and i could update to .91 all is well! Error message has gone.
I do have a couple other questions though, I will not be using another receiver at this point but would like to easily switch between having the tilt at level or at about 45 degrees for downward shots will i do this by plugging in and changing the tilt neutral? or will it be a gimbal servo adjustment.
Also in regards to mounting direction in the photo you can see my orientation, I would consider to be top back, in the manual i understand the power plug is the reference point. Question is when i select this and lean it to the front  which in my case is forward in the picture it says back and vice versa, also says top when sitting the way it is when i thought it should say bottom considering the bottom is facing the table.... Any thoughts are appreciated
Again thanks for looking into my issue super pumped to get the av200 runnin like a champ and shoot some bike park videos, Crankworx whistler BC this summer will be sick lol
I dont mind trying out new software so long as j can restore my old settings,  my comment earlier came from frustration of having a brand new setup and having it spaz on the bench lol,  im better now!
hmm picture didnt work... usb faces left, power faces back. gimbal is mounted parallel to ground chipset, ontop of gimbal/ ad6 landing gear
