now that I have a little taste of what a HUGE production is like I can see the need for more. I am curious what the pro's experience is with equipment failure from using the common setups most on here are using for light cameras. I.e. avroto/axi, maytech, hobbywing, turnigy,etc. esc's, controller failure.... I dont see motors being a weak point in a setup but if one was asked to bring a heli to another country to shoot using a scarlet/epic, what are the realistic options with a multi? It's really the esc's that worry me. I picked up a bunch of cameras on set to get a feel for the weight and damn they are monsters! Although they did have ext. monitors, batteries, grips/rails all which could be stripped. Any advice for the most reliable systems available for a dual operator setup. Money would not be an object to a certain point. I realize there is always a risk and redundancy is a must. we were flying an enormous hex and the size was great as it made it easy to spot LOS on set around 100+ people and 60+ cameras all rolling simultaneously. I also discovered the beauty of a dual operator setup. It does make it tricky for the pilot to orient in tight quarters though you cant focus at all on the rotation of the gear anymore. When the gimbal is rotated it throws the pilot off at a distance. I have a feeling this is going to be a single rotor heli to fly more than 5 minute shifts at a time with that weight. We held up a few shots because of the constant need to change batteries. Annoying. We would have needed 40 battery packs per day. And the noise of a gas SRH cant be that much louder than this thing. Any input from the guys who actually do this? I can understand fully if you dont want to share your secrets. I think the game totally changes when you need to lift a 15-20lb camera that costs so much.
