Blacksails
Hi Blacksails
Well the word is that if the skyline is rolling when you are panning then the z level is off. try it in a few locations but what you can do is remove the skyline, and place it up against a surface that you know is at 90deg to a level surface, use the header as a guide to line up the skyline and set the Z level that way.
Roll and Pan have an effect on each other in the firmware programming hence the movement.
Hope this helps.
Mike
Thank you, Mike. Much appreciated.
I will give it another go later this evening and report back.
Alex
