Mactadpole
Thanks for posting that Shawn
I always thought the PH log-in time was the minimun time to log new position - I guess thats why it wasn't working the way I thought it should, at least I know now
So basically the copter will not return to the original position if the Nick/Roll stick is moved wheather dynamic PH is on or off.
After reading that it looks like the only advantage of Dynamic PH is that its more accurate in windy conditions, is there any other advantage in using Dynamic PH?
Craig
I think the copter will return to the original position with Dynamic PH off (not selected) when you have not been at the new position beyond the Position Hold Login Time.
Example:
Positon Hold Login Time set to 5 seconds and Dynamic PH off (not selected). You are flying and have position hold on. You fly to a new position and let go of the stick after remaining there less than 5 seconds it will return to the original position. You again move to a new position and remain there longer than 5 seconds before centering the stick and it will hold at the new position.
With Dynamic PH on the Position Hold Login Time has no affect. You are flying and have position hold on. You fly to a new position and it will stay there. I think is so that if you are flying in windy conditions and trying to get a shot lined up you can gently nudge the stick to get the copter to move a little bit until it is in the exact position you need for the shot.
Again, I have no idea if what I am saying is correct!!! Try it with Dynamic PH off and see what happens.
BTW - Did you get my email?
Shawn
