Problem/Doubt with my custom first quadcopter
Hello Guys :). I'm building my first quadcopter, i've some problems but i solved, atm one problem is taking my sleep , it's my Front Right Motor/Esc, when the others motors are in high rotation, it's at extreme low rotation or no rotation and the Rear Left is a little diferent rotation
My Quadcopter:
Board: Crius Se 2.5 RUnning: Multiwii 2.4
Esc Hobbywing Flyfun 30a
Receiver: Fly Sky Fs-R9B
Control: Fly Sky FS TH9X
All esc, are calibrabrated with esc card: HobbyWing HW-BQ2006
My controll endpoints are all at 120%, Type selected: Heli |Modulat: PPM
My Controller
DroneTalk
R/C Expert
Staff member
if you model is not level or as yaw that motor would slow down or speed up, it's best to give it a test flight, taking care to slowly take off and notice any imbalance and land it.
I tried to do the first flight
I've some problems:
Front Motors works well, but in high rotation while throttle is like in 15%
Rear Motors dont work but if i move the pitch/yam stick they start
2 motors continue rotating while throttle is at 0%
SOme people told me to put the controller in acro/glide mode it's correct?
I'm Brazilian but i will upload a video showing it, I'm spéaking in brazilian but you can understand what happens
Before i upload you can help me with anything?
Old Man
Check the calibrations for all the ESC's again. It sounds like they are not operating together, as if some are calibrated differently.
