Working on a 1st build. Here's my order so far. Anything missing? I did order extras of certain things just to have "in case".
SK450 Frame
Taranis with X8R
DJI Naza-M Lite and GPS Combo DJI-Naza-M-Lite
SunnySky X2212 KV980 II Brushless Motor SNS-X2212-13-II X4
ZTW Spider 40A OPTO Multirotor ESC SimonK Program ZTW-Spider-40A X4
Genuine XT60 Connectors (4 Pairs, Yellow) EPB-9106
Glacier 30C 4000mAh 3S 11.1V LiPo Battery GLC-30C-4000-3S
Turnigy Accucel-6 50W 6A Balancer/Charger w/ Accessories
Hobbyking 60w Power Supply
ZIPPY Flightmax 3000mAh 3S1P 20C
Turnigy Battery Strap 330mm
HXT 3.5mm Gold Connector w/ Protector
5.6mm x 10mm M3 Nylon Tapped Spacer
5.6mm x 6mm M3 Nylon Tapped Spacer
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Red)
10x4.5 SF Props Black CW (2pc) CCW (2pc)
Simple Prop Balancer
Turnigy Receiver Controlled Switch
Extended Landing Skid Set for SK450 Quadcopter Frame
HobbyKing Universal Magnetic Propeller Balancer, For T Style And Standard Hub Propellers
Power Distribution Board (Octocopter)
3.5mm Gold Bullet Connectors (3 pairs) 3.5mm Plug (3 pairs)
4mm Heat Shrink Tubing - 13" Black 4mm Heat Shrink BLK
4mm Heat Shrink Tubing - 13" Red 4mm Heat Shrink RED
Gemfan 10x4.5 Nylon Prop Set (1x CW & 1x CCW) BLACK GF 1045 BLK
Gemfan 10x4.5 Nylon Prop Set (1x CW & 1x CCW) ORANGE GF 1045 ORANGE
Power Distribution Board (Quadcopter)
Soldering Station:
Product Code Product Name
FLS130 Acid Paste Flux #130 in a 2 oz Jar
AO9378 Aoyue Digital Soldering Station 9378
TLDBLCLAMP Double Clamp Stand with Magnifier
TLSOLDERVACUUM Manual Solder Sucker
MG4884-227G Wire 63/37 Rosin Core .025, 1/2 lb
SK450 Frame
Taranis with X8R
Soldering Station:
