Noticed that there are a few T680pro machines with Naza v2 fc. I then saw the commentary below on a website - and wondered where the assertion that the Naza v2 couldn't cope with anything over 650 had come from? Couldnt find anything on the DJI website [although it wasnot a detailed search ].
Any thoughts or comments - and would you really need to go to the Wookong to fly the T680 with gimbal and GoPro3???
DJI NAZA M V2 GPS or DJI Wookong WKM? Why would I need the DJI Wookong WKM over the NAZA M V2 GPS?The DJI NAZA M V2 and DJI NAZA M V2 GPS are both class leading in the hobby world, and at this time there is no other flight controller that offers the same level of flight performance, ease of setup and the features for the same price point. However theDJI Wookong M WKM is a professional tool to get a task done and is built to do a job, it’s able to hold its position with more accuracy and carry out autonomous flights with telemetry information sent to a laptop computer in the field, and where the law will allow for flights beyond visual line of sight, the Wookong M makes these flights possible. The Wookong M also has support for larger diameter QuadCopter, HexaCopter, X8 and Octocopter’s over 650mm in diameter, the DJI NAZA M Lite or the NAZA M V2 GPS do no support these larger frames which are over 650 mm across, which for many aerial photographers lifting up bigger pay loads like DSLR cameras with an OctoCopter or a X8 it’s a necessity to use the Wookong M, with these limits in mind, which are beyond both the NAZA M Lite and NAZA M V2 GPS it would be time to progress to the Wookong M. They are both fantastic, however the DJI Wookong M does it all, and that much better, in other words would you use a hammer to tighten a screw? It all comes down to selecting the correct tool for the job.
