35 Meters max with ImmersionRC 600mw Yellow Nano 5.8 Receiver, Blubeam Cloverleaf Ant
Hi,
i did some aerial fotos today for a friend and hocked up the video downlink gear. I took the kopter straight up for 30 35 meter and higher and my video signal dropped dead. I am a little disappointed hopping it can do at least 50 m plus.
I have the transmitter attached to my carbon landinggear, to one side of the DW Ext landing gear. Could that be the reason for this bad signal strength ?
Setup:
ImmersionRC 600mw
Cloverleaf Antenna, Bluebeam
Nano 5.8 Receiver,
also Cloverleaf Antenna, Bluebeam.
Macsgrafs
Boris, the antenna your using has a blind spot right under it, try an inverted V if possible or swing the antenna through 90 degrees & see what happens.
Ross
ah okay than i misunderstood the bluebeam guy, i thought he said head down or head up it should be mounted. I will try that thanks !
Macsgrafs
There was a thread over at RCG & the designer was saying that overhead can cause range problems, just swivel the whole thing 90 degrees & see what happens. Let me know will you my friend so that I can see what the range is like
Ross
I will gonna make the change tomorrow and than test. Will let you know right away.
Borneoben
Any update?
I am considering getting a 5.8Ghz system to replace my 900mhz system and i would also be using the tiny little Blue beams
Would be interested to hear how changing the position helped you??
Ben
Hi Ben,
it will take me to the end of the week to test it. No real flying possibility at the moment to fly it far.
juz
FPV pilot
Way too much carbon fibre. I avoid carbon and metal (as much as possible) for my FPV builds. Carbon can block and interfere with radio signals. You should get some serious range with 600mW. I run 300mW Vtx (1.3ghz) and can easily fly 1km.
krleas
FPV Freak
U cant compare 1,3gHz and 5,8 gHz. Lower frequency - large range. With 600mW i have good range between 400-600m. I use coverleaf and 13db patch.
With 900mHz and 1W my range is almost 2km with no problem.
@ Boris
Try on receiver normal antenna not coverleaf.
I had similar problem with Airwave 7ch 5.8GHz Receiver, when i used coverleaf my range was 10m or less or even black screen.
I puted on receiver normal 3db antenna, range was 300m.
krleas
can the cloverleaf or skew-planar antennae be used with overhead positions as well as long distance? I've got a dipole and patch on my receiver.
thanks,
bartman
krleas
FPV Freak
Yes.
And this is the best combo. Transmiter cloverleaf, receiver diversity with patch and dipole.
@Thanks Boris, nice to see u here.
juz
FPV pilot
Maybe, but with a good quality 600mW tx, over 1km is easily achieveable. Infact 200mW 5.8GHz will get you to 1-2km no problem (if you know what your doing) and the distance record for 5.8GHz 200mW is around 6km. 450metres?? HA, been done with 16mW on 5.8. And on that note, a 1w Vtx on 900GHz Vtx is crazy overkill, ask any experienced FPVer.
krleas
FPV Freak
I'm talking about distances without interference.
Right now im watching your movies, great job m8. U are really Freak.
So I guess my approach would have be to get the atenna as far away from the carbon as possible. So would the antenna directly on the landgear or 30 cm away from the nearest carbon piece make a significant difference ?
