BlacK-Eye : carbon quad for gopro3
B-DroniK
Here is my first creation, the BlacK-Eye.
Most of the parts are in carbon.
more information on website : www.b-dronik.com
Hope you will like it :)
B-DroniK
that looks cool.. just need some small carbon gear :tennis: are you running 2 3s batteries on there
I run it on 3S 10000mah, the total weight with LIPO and gopro is 2kg and it can fly 22-25 minutes
The gear is in alumium and the weight is very low, if I want carbon gear I need to add screws and fixation, so it would be heavier than simple alumium.
B-DroniK
I'm flying it with 13" prop, but the prop can be between 11 and 15"
here are the dimensions :
B-DroniK
I would assume the FC is mounted on the bottom plate close to the CG
You right, the FC is between the 2 plates, close to the CG.
The board in the front is the brushless gimbal controller (this board can also being mounted on the bottom plate)
B-DroniK
The usual model is made in 1,5mm carbon sheet.
But for heavy load and strong frame, here is a 2mm version off the BlacK-Eye :
(the arms and accessories are included in the kit)
visit our french shop on www-dronik.com
English version should be launched soon.
B-DroniK
WIN A BLACK-EYE*!!! (http://www.b-dronik.com/shop/product.php?id_product=28)
Multirotor Design Contest
How to play*:
=> Make your own design (hand or computer)
=> Give a name to your project, the name must begin by BlacK-*???
=> Send pictures and small describe by email => b.dronik@gmail.com
=> The validated projects will be posted on facebook => https://www.facebook.com/B.DroniK
=> The winner will be the one who will have the more «*likes*» the 16th June 2014.
=> A prototype of the best design will be draw, cut and tested by B-DroniK
=> Datas*:
Carbon 3K 1,5mm
Tubes 3K 16mm
Max diameter with motors 700mm
No limit of motors (3, 4, 6, 8,...)
