quick power question
djneils98
hi all
have an immersion 5.8ghz tx that needs either 3s or 2s power. However I like to run a 4s lipo.
is there a little converter that could step down the power so I can run the tx off the 4s?
Or I heard that you can take power of some of the pins on the 4s balance lead to only access 3 of the cells?
any help appreciated
Benjamin Kenobi
Easy? You call that easy?
My immersionrc VTX came with a lead just like you described. Just accesses three cells. I use an EZOSD which has a separate output for the VTX so you can dispense with the balance plug lead when using 4S.
I just wire them right to the power distribution board right next to en esc or power lead, can also go straight to an esc power pad line on a flamewheel frame. 4s goes straight into that little red and black plug. the red coming out of the 4 pin plug is 5 volts for a camera or hdmi converter.
Benjamin Kenobi
