What are some common exclusions in the Aerial Pak property policy?
Nuclear Events, War, Mechanical Breakdown, damage from Electrical Current, Wear & Tear, Volcanic Eruption, and Dishonest Acts of the insured. The policy should be carefully reviewed for more information. We will gladly provide a sample policy.
these exclusions pretty much nullifies the chance you'd see a payout on a claim imo.
I'm an aviation insurance specialist and have no relationship to or with that vendor. Although I've not seen this particular property insurance policy form, those are pretty standard "Physical Damage" exclusions on nearly any type of "Physical Damage" policy. As I understand it, this insurance product may not include physical damage so the exclusions may not even be relevant.
On the other hand, if the policy
does exclude liability coverage for losses resulting from those types of failures, then I agree, those exclusions would be disconcerting. Aviation policies contain those exclusions for "physical damage" to the vehicle itself but
not for liability coverages.
I'll try to breakdown each as they would typically apply to "physical damage" coverages:
1.) Mechanical Breakdown - This would be similar to your airplane throwing a rod. Aviation insurance would not pay for the direct damage to the engine caused by the rod failure but would pay for subsequent damage such as landing off-field and hitting a fence and damaging the prop, wings and would also cover liability to repair the fence.
2.) Electrical Current - If an automobile suffered damage to it's electrical system due to a short circuit or hooking up jumper cables incorrectly, the insurance company would not pay for the damage caused by that electrical failure. In aircraft, "Heat" is also an exclusion such as hot starts on turbine engines. Coverage can be bought to cover the hot starts under "turbine engine breakdown" coverage but it's very expensive.
3.) "Dishonest Acts of the Insured" - Your own dishonesty is not a form of "Pure Risk". For example, you cannot cover your business for "Employee Dishonesty" and then, as the insured and an employee, embezzle money from the business and claim it under insurance. "Pure risk" must not have prior knowledge, permission or expectation of loss. As an insured, you also cannot profit from insurance which is a doctrine known as betterment.
Insurance policies
do include approved uses such as "personal use for which no charge is made", "aerial photo for hire" or "any use of the named insured including for hire". As long as those uses are named, endorsed or specifically covered in the policy, the policy will respond regardless if the FAA or other authority considers them to be in violation of a regulation or law.
In twenty years as an aviation insurance broker, I've never had a claim denied. I'm aware of egregious policy breaches of warranty such as not fulfilling training requirements that have resulted in denials of coverage, but those are exceptional types of losses and completely avoidable.
I'd be happy to try to answer any additional questions.
