Earl E Adobtr
Paul
Motors Spin Up After Arming - Normal With Naza M? Never Mind
Well, here I am at the beginning again. After a few years flying with HFP, I decided to give the Naza M system a try. Right now it's sitting on my work bench without props. When I arm, the motors immediately go to about 1/4 speed. Then when I move throttle all the way up then down, the motors go to zero rpm and won't come back on until I increase throttle to about the halfway point. I'm using a Futaba T7C transmitter and Hobbywing 4 in 1 20amp esc board which I'm thinking may be the problem here though the Hobbywing works fine with other fc boards. I've done all the usual things like calibrating esc's through the receiver, setting the timing to low on esc's, resetting transmitter, playing with the settings in Assistant. Before I swap out the esc's I thought I'd give it a go on the forum and see if this is a known issue or I'm doing something wrong.
