I guess the only real reason for it would be to correct the horizon if needed.
So I have forsaken HDMI On
So I have forsaken FPV/Look down
Sorry to be a pain...
	You put the vibe kit on the front? Hadn't throught of that.
Yeah, sorry I knew it was the IMU (I just referred to it as the "vibration kit") and I could tell it was the V2. I just hadn't thought of putting the IMU/Vibration Kit on the front and I installed mine in the rear (only because that was how it was in DJI's illustrations). And thanks for the picks of the full setup... I'm gonna have to rethink some of the ways I did mine.??? You mean that silver metal box ? That's the IMU and get's connected to the Flight Control. My IMU might look different than yours 'cause it's version V2. The old V1 is a gray plastic box....
http://tienda.stockrc.com/DJI-IMU-V2-Upgrade
When mounting it the way I did (in front) you must watch out because it's now facing backwards...that must be set accordingly in the Assistant Software !!!
Chris
Hey Guys,
I'm just wiring mine now, and had the same question? Was this resolved, is it necessary to go analog, or can you SBus and still use the forward and facing down modes?
Also with regard to the the small 8pin and 6pin connectors on the Zen module. The top servo has 2 x 6 pin ports, does it matter which one I plug the Zen into?
And finally how are you mounting your modules on your rig? I'd be really interested to see pics of what you have done if that is possible?At the moment I'm favouring mounting the Zen module on the top of the top servo.
Thanks heaps for your help.
Steve Q.![]()
